Front brake hose to shock clips
eamon1.3
Post by eamon1.3 »
What type of clips hold the front brake hose to the shock on a Rocco? Put coilovers on my vento and they have a different type of clip for the hose. Standard vento shock has a c shape clip but new coilover has a wee tab on it just. I've seen the type of rubber clip thing I need before but can't find them anywhere. Cable tied atm but not a long term solution for brake lines
Re: Front brake hose to shock clips
cable tie is perfectly acceptable. it's only to stop it rubbing on the tyre
