Ive seen a 2ltr 8v engine for sale and Im wanting to use the bottom end on my 1.8 8v Scala.
Ive been told the engine code is WWO? <- is this a correct code?
Will it fit?
thanks guys
WWO engine
Re: WWO engine
just went onto club gti which is where i got the info from when i did mine some kind soul has put up a huge listing of engine numbers on there and i cant find wwo anywhere
the most common ones to use are
vw 2e or agg but the block is 16mm taller
audi 3a the block is the same height with a larger bore
there are others you can use but wwo dosent seem to exist
ask the person selling it to check again
Re: WWO engine
WWO, sounds like the beginning of a chasis number
- bluestreak56
- Funollie
Re: WWO engine
I was taking apart my AGG 2.0 today and on the inlet manifold it has WWO stamped, perhaps your advertiser has written the wrong code down?
