Electric Fuel Pump
Funky Diver
Electric Fuel Pump
Post by Funky Diver »
OK, so somehow I've managed to end up with a Yamaha R1 fuel pump... a NEW one, for silly money.
These things retail at £536 from the dealer, and when speaking to the parts guy at my local Yamaha dealership the reason they are soooooo expensive is that they never fail. Now why have I bought it I hear you cry (or mumble, or not at all).
2 reasons -
1, it provides the fuel at the right pressure (3 psi) consistently (it's a pump and regulator in one) for the carbs I'm going to be running (ZX9R Ninja Carbs)
2, it was cheap as chips compared to a seperate pump and regulator - it cost me £20 posted when I offered a guy an out of ebay deal after he'd listed it twice and it hadn't sold (naughty naughty, lol)
Soooooo, here's my "issue". It normally is bolted into a hole in the bottom of the bike's tank, with a seal and a plate. Now I'm quite prepared to cut said hole, but then I had another thought. A self contained fuel reservoir JUST for the pump / reg, which is topped up from the main tank. Sooooo, my question would be this, is there a pump avaialable that will draw fuel off the main tank and then stop pumping at a certain level? (say with a float switch of some sort mounted in the transfer tank)
So which would you say would be the better option and why? Anyone done anything similar in the past with experience to share?
I'm erring towards the transfer tank idea - as it'll be less affected by cornering and the like, but then for a cleaner install having it mounted in the tank would probably "look" better and not have a small tank of Petrol sitting in the engine bay.
GT Matt
Re: Electric Fuel Pump
Post by GT Matt »
Have you got a picture of it to help?
GT Matt
1988 Mk2 GTX
Funky Diver
Good Idea :D
View of base / underside
View from Side
The "thing" bottom right, near my little fingers is the outlet pipe - This protudes downwards about 1.25" including hte base of hte pump (so about 1.333" from base of tank to base of pump, if that makes sense?
Height of inserted part (so above the flange to the top) = circa 6"
Diameter (of the hole it would need to be "in") - circa 3.25"
Funky Diver
and how it fits in the original tank...
Part number 24 is the pump, 28 is the seal and 25 is the locking ring
