Soft brakes??
irishrocket
Soft brakes??
Hi guys im wondering after changing the master cyclinder and all pads and shoe's the cars brakes are still terrible iv bled the brakes countless times and still noting?the servo is working for sure as when the engine is not running the brakes are rock solid!!! Any suggestions please as it's ready for the road now and i kinda like being able to stop with out my foot nearly going through the floor
You can dress a pig in a suit but you cant stop it grunting
- Reverend Frog
Re: Soft brakes??
Sorry to sound condescending, but how long ago did you change them? It'll take three days or so for the brakes to bed in properly.
Scirocco brakes are notoriously soft anyway. It's just a question of how soft they actually are. Any time i drove mine after being in a modern car i thought something had happened to them. They really have no feel whatsoever.
Might be worth investing in some braided brake lines. They are supposed to stiffen everything up a bit. Apart from swapping over to a 256mm brake set-up, there's not much you can do beyond that. It's a matter of getting used to them.
Re: Soft brakes??
engine off and pump the pedal a few times to depleat the vacuum in the servo. now stand on the pedal firmly. does it slowly sink to the floor? this would indicate a leak somewhere. if it does, find the leak and fix it before driving it on the road again. if it doesn't i'll stick money on your rear brakes not being correctly adjusted.
irishrocket
Re: Soft brakes??
Reverend Frog wrote:Sorry to sound condescending, but how long ago did you change them? It'll take three days or so for the brakes to bed in properly.
i changed them last week :D Yeah from driving the gt version i see how bad the brakes are my foot nearly go's through the floor to stop haha
HotSoutheastWind
Re: Soft brakes??
I know, every time i jump in the Rocco after driving my modern daily car the first few roundabouts are always a bit "oh jesus"
Re: Soft brakes??
is there not something that can be adjusted on the bar that goes across the back of the engine bay? sorry i cant remember what the actual name for this gizmo is.
i have to stop drinking stella on a saturday night.
Re: Soft brakes??
done this yet?Nate wrote:engine off and pump the pedal a few times to depleat the vacuum in the servo. now stand on the pedal firmly. does it slowly sink to the floor? this would indicate a leak somewhere. if it does, find the leak and fix it before driving it on the road again. if it doesn't i'll stick money on your rear brakes not being correctly adjusted.
irishrocket
Re: Soft brakes??
I think the problem is with the adjusters on the back brakes as soon as you adjust them they reset
Re: Soft brakes??
gsf do a "fitting kit" for the rear brakes that i think includes new adjusters. you'd need to check though. chances are they've never been replaced. the problem is caused by either the wedge has worn smooth on it's edges (should be small teeth-ish on it) or the spring that pulls it down has gone weak.
did you check for pedal dropping?
irishrocket
Re: Soft brakes??
Yeah nate the pedal seems fine :D gsf website is impossible to use im never sure what im buying haha
- go-for-it1
Re: Soft brakes??
GSF's fitting kit does not include the wedge shaped adjusters, just springs and shoe fasteners
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
irishrocket
Re: Soft brakes??
Iv got a friend of mine whos a mechanic reckons he might have a machine that will force every bit of air out of the system so i hope this might help
Whitescala89
Re: Soft brakes??
I always thought scirocco brakes were pretty gash compared to anything else i have driven. I had new shoes on the back for the mot and have had to adjust braking routines and have bled the system twice.
ChrisPears
Re: Soft brakes??
Always had problems getting the brakes bled properly on the Scirocco, finally figured out that using an eezi bleed, and the pumping the pedal method at same time does the best job.
