Samco Hoses
Samco Hoses
Okay so I'm looking at cleaning up the under bonnet and was looking at a nice Samco kit but wasn't sure if the Goof ones were correct so I went straight to the source and called Samco.
Is there any chance someone can post Vw part Numbers for the Coolant hoses and the ancillary hoses so he can make a kit up.
Cheers in advance
mazellann
Re: Samco Hoses
Post by mazellann »
Samco already do both kits, I've got them on the GTI.
Re: Samco Hoses
Not according to the man at Samco and their catalogue doesn't mention them either hence why I called. He was wondering if the Goof ones would fit or wether it would need anything different before I shelled out and suggested part numbers so he could match anything up.
mazellann
Re: Samco Hoses
Post by mazellann »
i might still have the boxes/ receipt when i bought them, but i cant check until i get home at the weekend.
i think they are listed as mk1 golf gti !
Re: Samco Hoses
Ah superb!
Assuming then that there weren't spare hoses? That being the case I'll order thm
mazellann
Re: Samco Hoses
Post by mazellann »
You should get an extra hose in the coolant kit, on early cars theres a straight hose from the water pump to the metal water pipe and on later ones its like a 'T' shape pipe (think i've got that the right way round) but you should get both in the kit anyway.
Like i say i might be able to get you the part numbers if you can wait til i get home !
cheers
Tony
Funky Diver
Re: Samco Hoses
Post by Funky Diver »
171 121 051 G
533 121 101 F
171 121 109 F
026 121 063 A
171 121 611 AN
Then the last hose depends on whether you have an oil cooler above the filter housing... and there's 4 hoses showing for it.
TBH, some of it also depends on engine number too... the only hose that is "random" is the breather to the expansion tank.
b5byt
Re: Samco Hoses
Post by b5byt »
I bought the samco kit from venom last year, I didn't have any pipes left over tho..
1984 Scirocco Storm Cosmos Blue < Body has really had it, if you need parts off it let me know < Going.
1986 Scirocco Scala (Rocco-Jocco's old one) Having some life put back in to it
2001 Carbon Black E39 M5
2008 Carbon Black E60 M5
mazellann
Re: Samco Hoses
Post by mazellann »
Coolant hoses - golf gti mk1 1800: Part no SAMTCS36/C-B (5 HOSES IN BLUE)
Ancillary hoses - golf gti mk1 1600/1800: Part no SAMTCS35/C-A-B (5 HOSES IN BLUE)
Tony
Whitescala89
Re: Samco Hoses
Post by Whitescala89 »
How much are these?
Funky Diver
Re: Samco Hoses
Circa £100 for the coolant hoses... I stopped looking after that... OEM is fine with me.
Re: Samco Hoses
Cheers Tony,
Shall be ordering those presently
Jay4424
Re: Samco Hoses
Post by Jay4424 »
Funky Diver wrote:Circa £100 for the coolant hoses... I stopped looking after that... OEM is fine with me.
the OEM ones ain't cheep!
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
Funky Diver
Re: Samco Hoses
I should clarify... I have 3 sets of OEM ones so have a choice to make in terms of which ones I'm putting on. I 'm not slating hte hoses, just that it's £100 I don't need to spend right now with the hoses I have. If they finally blow up (the OEM ones) then I would probably change to the Samco ones.
Read back my post and it sounded like I disapproved and I most certainly don't. They're swish looking!!
Re: Samco Hoses
Yeah, they certainly are.
Just got to decide whether to shell out and grab them know or send everything else off for powder coating. Hmmmmmm
