core plugs
alib
core plugs
Post by alib »
hi everyone :help: Any ideas on replacing core plugs. Was going to take engine out and service but now time and money are an issue - have heard that if you loosen engine mountings, drop down pipe and bell housing it would be possible to twist the lump forward to gain access to the core plugs. Not mechanically minded i'm affraid. And whats with the 'C' clips, bet there going to be fun to put back on without the special tool though i have seen a home made one.cheers
Re: core plugs
would have thought you do these with the engine in, access from underneath with the car on ramps
