Hi All,
Am I right in thinking that you can use an 8v fuel dizzy, air flow meter and lines to run a 16v setup? I know the injectors and air piping will need changing.
Any thoughts?
Jason
8v Fuel Dizzy on a 16v Setup?
- Jay4424
Re: 8v Fuel Dizzy on a 16v Setup?
it ends up not getting top rpm/power as it can't get enough fuel through the system fast enough... i believe, Boumsong knows though, ask him!
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
- Brunty
I think you'd use a 16v warm up reg and tweak the fuel pressure.
Brunty
Ah ha that sounds familiar and makes sense. Im sure people have been using 8v ones.Brunty wrote:I think you'd use a 16v warm up reg and tweak the fuel pressure.
Yu can also use the same fuel lines correct? Just need to change the injectors?
Jason
As long as the thread between the 2 injectors is the same. Tho im sure you can use the same injectors on both the 8v and 16v - dont know if there is much difference in the flow rates but all the seals are the same so will fit fine
Ah ha! Just checked the part number and it look slike they are the same! 86 onwards 8v injectors are the same as the 16v.Birdy wrote:As long as the thread between the 2 injectors is the same. Tho im sure you can use the same injectors on both the 8v and 16v - dont know if there is much difference in the flow rates but all the seals are the same so will fit fine
Jason
