Don`t want too pay main stealer prices if i can help it,can anyone recommend a good brand ? Gsf are they ok for bearings ?
Bearings / rings ?
MrD
Bearings / rings ?
Righty i am not far off accruing enough cash to buy the bearings and rings for my 9a / kr build up. which ones should i go for? building this engine up too be very strong,as it`s going too take quite a lot of stick,flywheel will be lightened and balanced with the crank and the vr clutch i am fitting.Will be using Arp bolts.I will be aiming for around 170 bhp to start with,but the engine needs to be strong enough for future plans,mnot sure what they may be yet,but might possibly involve a turbo,have found with the current engine,that i want more power
Re: Bearings / rings ?
have you actually checked what the price is from your local main agent? for many parts they are actually cheaper than GSFMrD wrote:Don`t want too pay main stealer prices
MrD
No,not for this stuff,think i will though ,now you mention it
MrD
Cool,heard Victor reinz are good too
MrD
Going to call these people when i get back today,did e mail a price request earlier,but not heard back as yet,could prob get everything i need from them,oil pump,gaskets,bearings ,rings,so may get a little discount
http://www.fwthornton.co.uk/index.html
MrD
Think i might just call the main stealers,this is what they sent back
9A parts
RING SET £ 119.72
54MM JOURNAL £ 29.13
58MM JOURNAL £ 32.36
WE WOULD NEED NUMBERS FROM THE OLD BIG ENDS AS THERE ARE AT LEAST 3 TYPES ALL WITH THE SAME DIMENSIONS
ALSO NO SMALL ENDS AVAILABLE.
KR parts
VALVE GUIDES £ 4.28 EACH
9A parts
RING SET £ 119.72
KR parts
