Hi guys
I've recently changed carbs, from Pierburg to Weber. The car's running great, but I have 1 question.
I've changed from the original air box to a k&n filter, so the breather pipe on the Rocker cover is open. Should I try and get the adaptor plate to attach it to the k&n, or use a universal breather filter?
Thanx
Phil
Rocker cover breather pipe
- Risocco
Re: Rocker cover breather pipe
Personally mate I'd get a catch tank, they seem to run better with not breather back to the air box
Alex
Alex
- Ashrocco
With a catch tank doesn't it go back into the airbox? I have made one to catch the oil but have fed another pipe back to the airbox?
Ash
LEEP
no mate just run a 12mm hose from your rocker cover with a 12mm t piece to the catch tank and put a small uni air fliter on top of the t-piece and 1 on the side of the air box and one on top of the catch tanker as alex says there do run alot betterAshrocco wrote:With a catch tank doesn't it go back into the airbox? I have made one to catch the oil but have fed another pipe back to the airbox?
SCIROCCO GT
Member 934
Member 934
- Risocco
Nah Ash, pipe from the rocker to your tank. Then a little filter on the air box where the OEM breather from the rocker went. Jobs a good 'un!
Alex
Alex
- Ashrocco
I will re-jig mine then, made it out of a Guinness can
My boy believe's me that my car like's daddy's beer
Ash
LEEP
you know it babyRisocco wrote:Haha! Me and Lee, great minds!![]()
Alex
SCIROCCO GT
Member 934
Member 934
- The Autoad
Pancake filter that just sits on top of the carb? If so, and if you must, make sure you run ducting from the front of the car to feed it cold air, otherwise it will just suck hot air from around the engine.philiano wrote:I've changed from the original air box to a k&n filter
