239mm mk1 gti cailpers
LEEP
Post by LEEP »
are these the same as i have on my 1.6 gt or are these abit better :scratch:
SCIROCCO GT
Member 934
The Autoad
Re: 239mm mk1 gti cailpers
Post by The Autoad »
post '79 calipers will usually be the same as the mk2 (inscribed with "VW II")
Also: Your GT probably has solid brake discs and thicker pads, wheras GTi uses vented discs and slimmer pads.
LEEP
Post by LEEP »
The Autoad wrote:post '79 calipers will usually be the same as the mk2 (inscribed with "VW II")
i have vented disc on the front plus the slim pads so should be ok just wanted to know if there would be better :hugegrin:
SCIROCCO GT
Member 934
