K&N for Weber 32/34DMTL - 3 screws or 4?
Locked
Junglist
Post by Junglist »
i just sold a K&N I had fitted to my Weber but the buyer says it's the wrong one. He said the hole's the wrong size and it should have 4 screw fixings not 3. I thought the Weber was a direct replacement for the Pooburg and so it should fit the same filter hole. He's saying otherwise. Who's right?
I thought he might be mistaken which model Weber he has but he says he's had an expert confirm it's a 32/34DMTL. I'm confused because both the Webers I bought were sold to me as this model and fitted the standard air filter and had 3 filter fixing points. Also, both the K&Ns i have bought in my time were sold to me as being for this model Weber and have both had 3 fixings and standard filter size aperture.
Who's right and who's wrong? Or are there different size Weber 32/34DMTLs?
LEEP
Re: K&N for Weber 32/34DMTL - 3 screws or 4?
Post by LEEP »
hes wrong mate my k&n had 3 fixing bolts as do all webers 32/34 carb :scratch:
SCIROCCO GT
Member 934
Jay4424
Post by Jay4424 »
there is a rubber gasket with 4 holes though, does he mean that?
which 3 screws do you mean? (on a circular ring, or under neithe the carb or which, where!!!
...infact I know can;t remember, will have a look at mine when I get home!
Jay.
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
go-for-it1
Post by go-for-it1 »
See the pics in James Butlers post about doing the head gasket, are they any use?
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
Junglist
Post by Junglist »
It's where the filter goes on the carb, the 3 screws in a circle. It was a filter i sold him. He's sending it back to me for a refund, it's philano off here.
LEEP
Post by LEEP »
the 3 screws screw into the top of the weber then the k&n goes over the 3 screws and then bolts on to the weber :hugegrin:
SCIROCCO GT
Member 934
Jay4424
Post by Jay4424 »
LEEP wrote:the 3 screws screw into the top of the weber then the k&n goes over the 3 screws and then bolts on to the weber :hugegrin:
seconded
'52 BSA A10
'03 Suzuki GSX1400
Junglist
Post by Junglist »
Yeah that's how mine is. So there is only one type of 32/34DMTL Weber then for definite? So he's definitely wrong, he must have a different model? Cheers people. Thought i was going mad for a minute.
A in M
Post by A in M »
http://www.funkydiver.com/wp-content/up ... ll0001.pdf
have a look at this, kindly supplied by funkydiver. Part no 18, the air box adaptor, fits to the Weber body with 4 screws that are part 19. I would have thought that the K&N used the same 4 fixing points? Anyway, I need a K&N for my Weber. I'll pm you and perhaps we could arrange something?
Funky Diver
Post by Funky Diver »
Definitely 3 screws.
Junglist
Post by Junglist »
So i'm thinking, looking at that picture, that the part with 3 screw holes for the filter is an adapter that presumably philano hasn't got on his weber, which is why he has 4 screw holes. Everyone else i've spoken to meanwhile has this adapter fitted to theirs as the Weber 32 /34DMTL generaXlly comes with it already on. Am i right with that deduction or completely barking up the wrong tree?
Funky Diver
Correctomundo.
Junglist
Post by Junglist »
So he does have a 32/34 after all and so do i and neither of us are wrong and i'm not going mad! Thanks everyone. I'll let him know.
markh
Post by markh »
Junglist wrote: Also, both the K&Ns i have bought in my time were sold to me as being for this model Weber and have both had 3 fixings and standard filter size aperture
If one of those is the one i swapped (not sold) with you for a standard airbox, at no point did i say it would fit a Webber, in fact i said it was off a standard Pierburg. Just wanted to clear that fact up.
Junglist
Post by Junglist »
Makes no difference now anyway, problem solved. Cheers though!
Locked
