Hi all,
quick question as i need to order some vacuum tubing (replacing the lot on the pierburg)
What is the internal/external diameters of the pipe?
Its a Pierburg 2e2, on a 1.8 carb'd scirocco scala.
Cheers, Dan
Vacuum tubing diameter
Re: Vacuum tubing diameter
Get it from the dealer, correct fit and OE
or get it from your local motor factor - just take a bit in with you and get them to match it up
