mounting fuel pump?
mounting fuel pump?
where is the injection pump mounted under the scirocco? i've had a quick look under the car but can't seem to find anywhere towards the rear of the car where it would bolt on but it was starting to get dark so that probably didn't help. also do mk2 golf mounting brackets fit on to the scirocco?
Re: mounting fuel pump?
Under the drivers side near the rear wheel arch,so of where a rear passengers ankles would be
where does it dolt on? i think i've found where your on about but there's not much room there and i can only see one place that it could bolt on to the chassis. if this is the right place then there's no way the mk2 golf injection pump will fit. what options do i have apart from finding a pump off a injection scirocco?
It`s all mounted on a sort of steel plate,the pump will be inside a rubber boot,just follow the fuel lines,all of this was rotten on my gtx,ended up removing everything,and starting from scratch.
i'm going from carb to injection so there's no pump there, just trying to find where to bolt my injection pump to.
This is what the bracket looks like.
Stainless steel items sold here...
http://www.golfmk1.co.uk/FuelPumpBracket.htm
