Flange fitting for hotttuning s/steel manifold ?
MrD
Post by MrD »
Any idea where i can get one from ? scrap yard from a vw ? it`s the sort of olive shaped flange,with 2 holes for bolts.Or would an exhaust fiting place have something i could adapt ?
Tim_R
Re: Flange fitting for hotttuning s/steel manifold ?
Post by Tim_R »
My 16v one came with a flange, springs and bolts to be attached to the exhaust. Most half decent customer exhaust makers should be able to help sort you out though.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
MrD
Post by MrD »
Cool that`s good to know :hugegrin: .Think i might get my mate to knock something up,i have a 4ft length of s/steel tube in 2in diamiter.
Sure i could join thay more easily than how it is a the mo.
How loud would it be if i removed the middle box,and just had the supersprint back box ? It sounds lush at the moment,more like a big sports bike than a car,when it`s on the cam it sounds dirty,can`t help myself,short blasts of acceleration :blush: .
Had a 16 v escort try it on in Huntingdon the other day,oh my was he embarassed
MrD
Post by MrD »
Been told the vaux astra use a pipe with the same fitting,so off to the scrappy,there are plenty in the local one,want to get it all ready before i remove the current one.
What is the optimum bore size for a tuned gtx ? was going to use 2inch stainless i have here
