Pierburg carb on ebay (one day left) UPDATE
Niall
Post by Niall »
Is this Carb compatable with my mk2
:ebay: http://cgi.ebay.co.uk/VW-GOLF-MK2-CARBU ... 240%3A1318 :ebay:
Only a day or so left so I need and answer quick,
It's exactly the same model as my busted up pierburg (I'm not switching to weber yet)
but its from a 1.6 and mines a 1.8
Will this make a diffrence?
I'm no expert you see
lukey
Re: Pierburg carb on ebay (one day left)
Post by lukey »
it will work on you 1.8 mate you'll just have to swop the jets over as the on on fleabay will be jetted for a 1.6 and yous is a 1.8 not a har job to do to be honest :chill: , if i were you id just bite the bullet mate and get a webber so much easier than the poobergs :dash:
Niall
Post by Niall »
Niall
lukey wrote:it will work on you 1.8 mate you'll just have to swop the jets over as the on on fleabay will be jetted for a 1.6 and yous is a 1.8 not a har job to do to be honest
Ive got the pierburg...
You mentioned changing the jets on it.
Can i just change the top jet or will I need to open it up to change the jets inside
ie. just the idle/fuel air jet
or the two main jets?
As much detail as possible please as i am useless
lukey
Re: Pierburg carb on ebay (one day left) UPDATE
Post by lukey »
you can do the whole lot from the top mate just the screws (jets) in the top when you take the air filter off the top mate :chill:
