Window Regulators - Bosch and Brose
neverweaken
Post by neverweaken »
Hi guys,
I had a Bosch regulator in my Mk2 Storm,
Pulled it to replace it with a Brose part I bought from another forum member.
The Brose regulator is much longer and the mounting points are about 15mm forther apart.
I cant see how I can get this Brose regulator to fit, is it possible?
When I put it in the door and mounted the top bolt, the top of the guide and cable was coming out at the top of the door
Bosch (original)
Brose (replacement)
They also have different connectors but that is easily sorted.
