fuel tank leak
fuel tank leak
i went to fill up my roccco last night befor the budget pushes the fuel prices up
to find that once it was full and i got it home , it decided to leak all over my drive
its leaking from the lip around the tank on the side nearest the drivers side , is this a common problem? and if so can it be fixed or is it a new tank job, if so do any of the golfs share the same tanks
Re: fuel tank leak
if it's leaking from the seam of the tank or a hole (even a small one) then you need a new one. You can get them from gsf. The other ways it could leak are either the seal where the filler neck attaches, or the seal in the inspection hole at the top of the tank ( under the rear seat).
