washer reservoir swap
- Vonlard
I have shaved the washer bottle from under the bonnet by routing the rear bottle to the front washers but need to swap the wires for the pumps in the connector at the stalk. Does anyone know what wires are for what in the connector so I can have an easy 5 min job while I wait for the paint on the suspension to dry. Don't know if this Is the normal way to do this but seamed the most straight forward
It was meant to be a cheep run around till I finished the Type 1, Now I have 2 projects and an obsession
61 Type 1 Gasser project
88 Scirocco GTX rolling project
