What color/code is this?
Boumsong
Post by Boumsong »
Ok..Looking on a few charts and at other peoples cars..I still can't work this out.
I need a code for the car and another for the door..
2k Painter and Powdercoater
bluestreak56
Re: What color/code is this?
Post by bluestreak56 »
E plate 87/88
Looks like sapphire metallic to me (from the pics) but could easily be another..
Check here:
http://www.cybertects.co.uk/scirocco/pa ... s/1987.php
http://www.cybertects.co.uk/scirocco/pa ... s/1988.php
marcus
Post by marcus »
At the risk of suggesting the maybe obvious, have you checked the owners manual if you still have it (should be on a sticker inside the front cover), and checked the boot (should be a sticker on the boot floor under the mat or on the lower part of the rear valence (is that the right word for the bit between the taillights?).
Won't help with the door though...
1985 GTL 1.8
Boumsong
Post by Boumsong »
Cheers for the tip, I found the sticker and it appears to be Sapphire Metallic, sweet! I can get it sorted now..Hopefully it'll be off to the bodyshop on it's birthday!
