I have a 1988 GTX. When I turn the key to ignition 1 whee the warning lights, light up. Should I get an initial whir of the fuel pump. I have checked all the terminals on the fuse box and I get the correct voltage on all the pins. I have taken the relay cover off to visually see if the relay activates. It does not at this point. It only kicks in after I start it about 1.5 seconds after crank. Once started I can here the pumps. Both pumps work if I jumper terminals 30 and 87 (relay numbers) the car then drives normal once started. I can hear the pumps for on second before they shut off after I switch the ignition off.
I suspect the relay to be faulty but did not want to waste my money.
I am having cold start problems and wondered if this is causing it.
Other possible causes could be dribbling injectors but I wanted to start with basics before I dig deeper.
Hope someone can help.
