I've been driving around for a while with no working washers so thought i'd have a crack at sorting out - a leak.
New washer pipe, a new t piece section, and nope, still dribbles out the jets. Have tried a different washer pump and also flushed the system but to no avail. I've come to the conclusion it could be:
The jets - gung'ed up - how do i clean them out?
The new pipe/hose is too thick - so overall there's not enough pressure? - have tried just a direct pipe to one jet without the t-piece but still dribbles?
Not enough current getting to the pump? - although it sounds fine
Both pumps are faulty! - Which seems odd - as the spare was defo working!
Advice / solutions anyone?
Washer Jets / Pipes / Pump
Austin
Four Sciroccos, four gone, but at least I know all parts from most current one went to good homes....
Re: Washer Jets / Pipes / Pump
Use an air line to blow the jets out then use a pin.
Might be worthwhile seeing if you get your hands on a GL washer pump as these had to cope with
spraying water onto headlights as well, might be more powerful, worth a go?
- The Autoad
GLs ran two standard pumps.
as the man says, get the airline out!
