Hi
Looking at getting some of these for my rocco, they are 16x7.5 offset is 25, however they are 5x100 so i would need adaptors (15mm) with these on the car as well would the offset be okay?
Thanks in advance
Keskin KT5's
Re: Keskin KT5's
Would the offset not be 25 plus the 15mm of the adaptors making the offset 40? rather than 10? Excuse me if im being an idiot!!
Re: Keskin KT5's
i always check thus site linked on the FAQ - http://sciroccoregisterforum.co.uk/faq/ ... cd-offset/
LOWER the ET more the likely hood of touching arches or 'poke' depending on diameter of wheels/tyres.
Re: Keskin KT5's
Cheers guys, just had a chat with an engineer from work who has explained it all to me (minefiled comes to mind!)
GTXTRA - These should be with me between xmas and new year so i will look to come and collect that mk1 grille in early Jan if thats okay?
Re: Keskin KT5's
Lower off set the more the wheel will stick out, so if you use adaptors or spacers the wheel will stick out further, so a lower etdaveyg wrote:Would the offset not be 25 plus the 15mm of the adaptors making the offset 40? rather than 10? Excuse me if im being an idiot!!
Re: Keskin KT5's
These any good to you? Currently on A Mk1 MR2 which is same PCD as the Mk2 Scirocco.
Will be available soon. :)
