Just after i little bit of advice before I damage something.
Need to fit my Power Rohr but not sure if I need to amend the flexi pipework. Tried a trial fit and there just doesnt seem to be a way to bend the pipes to fit. So if anyone has fitted one any tips please on best way.
JXP
Power Rohr Fitting
Re: Power Rohr Fitting
Bend pipes ?jxp wrote:Just after i little bit of advice before I damage something.
JXP
Remove old plastic induction pipe, undo the metering head rubber boot so that it is loose but wont pop off.
Insert power rohr to the manifold end first, then line it up with the boot on the metering head, (you might need to push the power rohr a little further in to the manifold rubber boot), if needed twist the metering head boot to match up well with power rohr pipe, insert as far as poss and tighten the two worm drive clips up. Job done.
There's no need to bent any pipe work there almost a direct fit..
jxp
Cheers for the pics, will adjust the metering head boot as that was where it didnt seem to match up.
2002 Passat 1.9 TDI 130BHP
- Vonlard
I have one sitting in my garage that I cant fit due to the 22mm master cylinder and reservoir getting in the way
It was meant to be a cheep run around till I finished the Type 1, Now I have 2 projects and an obsession
61 Type 1 Gasser project
88 Scirocco GTX rolling project
