Has anyone ever run any fuel system cleaner through their cars?
My economy and performance has dropped, so want to go through some of the simple options before delving any further.
Injector / Fuel System Flush
Austin
Four Sciroccos, four gone, but at least I know all parts from most current one went to good homes....
Re: Injector / Fuel System Flush
how long since it was last serviced? what state is the air filter in? have you got a binding brake?Austin wrote:want to go through some of the simple options
Austin
Last Month, actually, start of this month (November) - New Oil, Air Filter
I've just changed the plugs, and got a new air filter, oil, oil filter, fuel filter, discs and pads (put solid disks on as a temporary measure about 2 months ago).
It's still doing 39 mpg, but I'm used to it easily doing 45!
You will use more petrol in the winter, choke on for longer, your headlights on more, heater blower running, heated rear window etc.
Might be the reason?
Austin
Good call! :)
