Front screen seal
Transporter 2
Front screen seal
Post by Transporter 2 »
Hi all I am new to your forum so be gentle - Brought a 1990 mk2 scala fi during the summer 175,000 miles just run in !! has a few issues that i will post seperatly to keep things simple. But my main problem at moment is water in both front foot wells, planning to renew screen as it has a few chips in anyway, to eliminate the leaking seal problem, however new seal appears to be maindealer only at £80++, just wondered if anyone knows of an alternative supplier, or any other options, like resealing the original screen in situ and success likelyhood . Thanks for now :newbie:
Tim_R
Re: Front screen seal
Post by Tim_R »
Hi and welcome along. :) 175k is just a baby ;) I'm also looking into getting a new windscreen seal and currently thinking that the dealer is the best bet for one that will do the job properly. I'm in the same situation as yourself but have already replaced the glass and tried resealing the old seal in place after cleaning off all the old hard sealant from a previous fitting. If anything I'm getting worse puddles now than i was before.
Separately when you take the old screen out, you'll either find rust on the lip where the seal sits which will need treating, or like mine, the seal has rubbed away the paint to bare metal and will need paint before putting new glass in, just to stop it rusting out and leaking in the future.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Transporter 2
Thanx for your info on that - was going to have a go resealing it over the weekend end, but you're probably right the only sure cure is a new genuine seal and screen £££££! and repair any damage. Thanx for help. Will update as it happens.
Tim_R
Post by Tim_R »
No harm in trying to reseal it, just that it makes it a much longer job to sort out and clean up later if it doesn't work. ;)
Mk2 Golf Gti 8v
Transporter 2
Any ideas what the best stuff is to try and reseal - was going to try a polyurethane type sealant.
dozzum
Post by dozzum »
Why not get windscreen cover on your insurance and then claim on it???
Tim_R
Post by Tim_R »
Not too sure what the stuff I've got is, its a non setting black snot helpfully labeled as "Windscreen Sealant" and for "Professional use only"
Mk2 Golf Gti 8v
Transporter 2
Thanx guys will check what cover i have to see if it covers screen - and try and find correct sealant - Rocco now sorn for fuel tank swop and new clutch - so plenty to get my teeth into - will be in touch as problems evolve !
