Hello
I would like to know some details about converting a carb car to injection..(mk2 rocco)
What parts exactly do I need ?
Is the wiring for the pump there ?
And how big of a job is it ?
Any help much appreciated!
Converting a carb car to injection
- b5byt
1984 Scirocco Storm Cosmos Blue < Body has really had it, if you need parts off it let me know < Going.
1986 Scirocco Scala (Rocco-Jocco's old one) Having some life put back in to it
2001 Carbon Black E39 M5
2008 Carbon Black E60 M5
Re: Converting a carb car to injection
tank.
fuel pump, fuel accumalator, lift pump
Wiring loom for pumps / lift pump
pump relay.
maybe lines as i think carb lines are smaller (someone will confirm)
engine loom if your going to make it 1.8 or engine loom for what ever engine
engine wise the whole shbang, manifolds metering head, etc
MFA clocks and stalk if you want to fit that lot...
All i can think of at the mo bud
pump relay.
- b5byt
It would be for a 20v so wouldnt be using the kjet system..
is it a straight plug into the fusebox etc etc or does anything need making/modifying ?
Thanks for your reply!
cool..b5byt wrote:It would be for a 20v so wouldnt be using the kjet system..
Not to sure, i would think there is some thing you have to do re the imobliser i think it's built in to the key/ barrel.
There should be a lot of answers on club gti, ed38 or even the phirm can give you an insight of what needs doing....
- b5byt
Sorry bud I wasnt being clear..
I know all about the 20v, just dont have a clue about the carb to injection system.
As for the key barrel thats if your using oe management, not needed if using qpengs or another standalone system
kk
Well i think pretty much as the 2nd reply really to convert it..
