Ignition problem!
Posted: Wed Nov 04, 2009 2:44 pm
Firstly apologies if this has been covered elsewhere (i did look).
I've got a Mk2 GT ('87) and i was sorting an ICE problem when i went under the bonnet to make sure the power cable for the amp was connected properly, i went back to the car to start the engine to and it doesn't start, the battery, oil and oil temp lights come on, the interior lights and exterior lights work so i don't think its a battery issue. I checked all the earth's in the engine bay and all seem fine. (However in a separate issue the earth wire from the ignition coil isn't connected to anything and i can't see where to attach it! Though this was the case before i tried to fix my ICE and the car started fine.) I've run out of ideas, I've checked the fuse-box and none of the relevant fuses are burned out , the head unit and amp fuses have not blown and the connections to and from these seem fine, so i can't see what i've done haha.
Please help cos i've run out of ideas! And any ideas where the earth to the ignition coil connects would also be helpful.
