Gearbox drain key?
- AndyJ
Gearbox drain key?
Tried removing the drain plug on my Scala (using my bolt and two nuts tool) and it is in there tight. It was put in by the neanderthals who caused the gearbox to seize back in 2008 and I reckoned they overtightened it. Anyway, I think I need to get the proper tool for the job, which GSF don't have in stock. Any idea where I can one from? Google searches come up with the Draper 17 mm on a 3/8" drive. I don't think it will be man enough for the job of loosening it.
Andy
Andy
Re: Gearbox drain key?
is it a 17mm allen head? (memory a bit hazy!) if so, i'd go for either:
1] one of these on the end of one of these
or
2] a 17mm allen key (try a tool shop, or even hellfrauds) with a bit of stout pipe (scaff tube?) over the en o it to make it longer.
loosen it with a jerk as opposed to constant smooth pressure
or
- AndyJ
Aaah
I've been a bit stupid I thought the engine oil was the same as the gearbox oil,
- Jay4424
the only thing that gets me about the Gear box oil, is that you can only change 2 liters of its 6 liter capasity (please correct me if I'm wrong) but when I went to change mine, thats all I could get out ( and back in) with out removign the gear box... the drian plug I found was on the side of the box (near side) not at the bottom.. I don't get it!
Jay.
Jay.
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
Gearbox capacity is only 2 litres for all the 5 speed 020 boxes.
Link to FAQ on ClubGTI
http://www.clubgti.com/forum/showthread.php?t=26910
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
Forgot to add to my comment,
I add an engine oil addative to the engine oil change (can't remeber name) VMX1 and it made a big difference to the gear change which is why I thought they must be the same!
I'm confused, did you fill your gearbox with engine oil then add the additive, or did you just add the engine oil additive to the original gear oil? Using engine oil in the box won't do any harm in the short term, however it doesn't have the additives that can allow the oil to cope with the extreme pressures that the gears put the oil though and keep the lubrication properties.larky wrote:Forgot to add to my comment,
Mk2 Golf Gti 8v
Mk2 Golf Gti 8v
No I just changed my engine oil (emptied from the engine sump) I added the addative at the sametime as the engine oil and gave the storm a test drive and my first gear selection problem was much much better, so I assumed the engine oil and gearbox oil were the same
- Jay4424
capasity only 2 liters?... B*ll*cks.
sorry, read your manual, it states 6 liters complete, 2 liters drain and refill in situ.
...I'm going home to check that now! sorry if I'm wrong again!
Jay.
Jay.
'52 BSA A10
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
- Jay4424
bollocks, got the amounts right, but not the units.... its all in Pints! not Liters, sorry guys!
(hangs head in shame!)
Jay.
Jay.
'52 BSA A10
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
you aren't a reformed british leyland owner, are you?larky wrote: I assumed the engine oil and gearbox oil were the same
