i know this as been said before but what am asking is i want to keep the 1.6 engine but could i fit a set of 600 bike carbs on it and if so what would i need
regards
lee
motorbike carbs
MrP
Re: motorbike carbs
Carbs, fuel pump, pressure regulator, inlet manni, new cables and fuel pipes. Pretty much it!
Look on clubgti, there are a few how to's on there.
LEEP
Re: motorbike carbs
could i not use the mech fuel pump on the car already as i dont want to change the engine and are the rest of the kit easy to get hold off
SCIROCCO GT
Member 934
Member 934
MrP
Re: motorbike carbs
I think most (if not all) bike carbs need 3bar fuel pressure, I know that k-jet uses 5bar so the original pump would kill the carbs.
You can use the bike fuel pump (as I am doing with my carbs) which means you wont need a pressure reg.
The rest of the kit is easy, the hardest bit is getting a inlet. It can be custom made (which costs £150+) or as i'm doing using a chopped down inlet with samco hoses to join the inlet with the carbs, but i'm using a 16v engine so the inlet can be used like that, no idea about the inlet on your engine?
I also forgot to mention that the carbs will need new main jets and setting up properly!
- Risocco
Re: motorbike carbs
Lee mate, some bike carbs need to positioned exactlly as they were on the bike in terms of angles, otherwise they wont work
Alex
Alex
- Brunty
Re: motorbike carbs
Personally I wouldn't bother with bike carbs. Save up for a set of DCOE 40s.
They wouldn't thank you much for 3 bar of fuel pressure either! More like 1-2 psi.
Brunty
MikeH
Re: motorbike carbs
It's your money, but IMO it's a waste of time on a 1.6 8v. Carbs with no manifold cooling, sitting above a hot exhaust - recipe for an unreliable car. If you want to fit bike carbs, buy a 16v lump first.
If you really want to keep the current engine, Spend your money on a flowed cylinder head and a cam, or just an injection head, if the budget won't stretch to a flowed one. Get the head skimmed to lift the compression ratio up from the wheezy 9:1 to about 10 or more, and you'll see a real power and torque increase, even on a weber 32/34. You'd still be better off with a 1.8 though ;)
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
