leak into passenger footwell
nimac
Post by nimac »
Hello All
I have a mk2 GTX. When i bought the car it had a leak into the driver and passenger footwell but i wasnt too bothered as i thought it could be easily fixable.
I did the usual, clear out the sunroof drains etc... but no luck, then i took out as much of the dash as i could, had a look around but still no luck, the leak into the driver side stopped after this but the passenger side is still getting wet.
Anybody have any thoughts.
Cheers.
Re: leak into passenger footwell
Check your heater matrix mate, it is on the passenger side, quite awkward but an easy fix.
Niall
Post by Niall »
I believe this should help, if not solve the problem.
http://sciroccoregisterforum.co.uk/faq/2009/03/12/test/
katemate
Post by katemate »
Hiya.
Mine did this years ago - it was indeed the heater matrix, replaced the seal inbetween it and the body, right as rain since.
KATE MATE
Mk II Havanna Storm 'Jolly'
Mk V Golf R32 'Lewey'
