Hey guys, was wondering if you could help me.
I'm back at uni but my car is stuck at home in a garage as its been suffering from the dreaded filler neck problem, I had a filler neck on the way from someone on here but due to a couple of problems it hasn't come yet.
Anyway the garage can't source one and I ideally need it fixing soon, what should i ask the garage to do, i heard you could use a MK1 golf and cut it down?
Its a MKII GTII. any help appreciated
cheers
Andy
filler neck
Re: filler neck
location of car? in case an alternative source for pipe is available.
search for user 'nate' - in his posts there will be a reference to the golf pipe option.
there is also this solution - http://sciroccoregisterforum.co.uk/carf ... ler#p18954
moving this too.
moving this too.
