I can see what looks like a little clip hidden under the ring on top of the actual seat - it moves a bit with a screwdriver, but could be a red herring?
Any ideas?
Anyone know how to get headrests off?
Re: Anyone know how to get headrests off?
That clip is what holds the headrest in.
You need to gently pull the loop end out with the end of a screwdriver.
Be careful not to rip the seat material if you slip.
It is shaped like a U shape and there is one on both poles of the headrest.
Once both clips are removed the headrest will just pull straight up and out.
1974 Scirocco TS ,1978 Scirocco GLS, 1980 Scirocco Storm, 1981 Scirocco Gti.
