How To Remove Bumpers ??
Posted: Fri Sep 25, 2009 3:57 pm
by GordonC
Hi, Does Anyone have any guides or tips on how to remove the front and back bumpers off a mk2 ?
As the paint is all flaked and need resprayed.
Re: How To Remove Bumpers ??
Posted: Fri Sep 25, 2009 4:43 pm
by Tim_R
Open the bonnet and undo the 4 19mm bolts that hold it to the chassis legs then pull. Disconnect the foglamps if you still have them first. For the rear, open the boot and undo the 4 bolts and again it should slide off. :D
Posted: Fri Sep 25, 2009 5:01 pm
by GordonC
Thanks mate I'll have a go at that
Posted: Fri Sep 25, 2009 5:18 pm
by GTXTRA
mind your toes- when bolts off the bumper will slide out quite quickly.
also the ambient temperature sensor is plugged into the back of the osf section of bumper.
Posted: Fri Sep 25, 2009 5:35 pm
by the edmundator
GTXTRA wrote:also the ambient temperature sensor is plugged into the back of the osf section of bumper.
But only if you're fuel injected.
It's an easy job (unlike getting the plastic covers off the bumper irons, which is a pain in the arse).
Posted: Fri Sep 25, 2009 8:01 pm
by jimmyconway
Say what? Is that for real?
Posted: Fri Sep 25, 2009 8:07 pm
by GTXTRA
jimmyconway wrote:GTXTRA wrote:also the ambient temperature sensor is plugged into the back of the osf section of bumper.
as ed pointed its just on the injected cars( which came with a trip computer combined with the clock - amongst other things it shows ambient temp).
Posted: Fri Sep 25, 2009 9:53 pm
by bluestreak56
I wondered what that doohickey was!
