Hints, tips and guides for repair and modification - the FAQ section on the main website is worth checking first for information relating to common faults and technical help. Useful posts and guides will be added to the FAQ
http://www.sciroccoregister.co.uk/scirocco-faq
Posts: 3957 Joined: Thu Apr 02, 2009 9:28 pm
Post
by mark1gls » Tue Sep 22, 2009 9:54 pm
I took this out the fuel tank at the weekend, is there suppost to be any thing on the end of the fuel pick up pipe, its out of my Mk1 GLS scirocco.
I know the Gti has a lift pump fitted but it also has a mesh filter on the end of the pick up pipe, should there be one on here?
monzajake
Posts: 744 Joined: Thu Mar 05, 2009 8:13 pm
Post
by monzajake » Tue Sep 22, 2009 10:02 pm
no fella as you have an inline one at the engine end.
Could be wrong tho
FuzzyEdges
Posts: 56 Joined: Sat Jul 25, 2009 5:17 pm
Post
by FuzzyEdges » Tue Sep 22, 2009 10:03 pm
Anything rattling around in the tank?
It may be that!!!
It's nice to be nice.
Posts: 4045 Joined: Thu Apr 02, 2009 10:37 pm
Post
by Nate » Wed Sep 23, 2009 11:15 pm
that looks rather like the strainer has been removed and replaces with a bit of fuel hose so it still sucks from the bottom of the tank
