worn gearbox/clutch?
Mailo
Post by Mailo »
In the last few days a new problem has come up with my 87'mk2.
When I put the car in first and take out the clutch there is a rumbeling feeling and the car jumps a bit for 1/2 second, when the clutch is all out it works fine. until I change to second gear, same problem there.
gearbox or clutch?
Boumsong
Re: worn gearbox/clutch?
Post by Boumsong »
Have you checked all the engine and gearbox mounts?
It could also be the clutch struggling to get grip until the car is rolling - worn clutch
It's unlikely to be anything to do with the gears/gearbox otherwise the problem would be constant whilst moving.
2k Painter and Powdercoater
