recomended engine oil.
anybody know what engine oil is best for the old rockos? i rang VW and they recommend 10/40. yet the haynes manual says 15/50 or 20/50 which seems a bit thick too me. what is every one using in their cars?
Re: recomended engine oil.
10/40 Magnitex, might be expensive, but as much protection as possible is worth it :) i also noticed a considerable differance in performance over the very cheap oil that had been put in prior to me owning it :)
Boumsong
Good oil is well worth it. You'd be surprised at how much difference it makes. Same with anything, godo filters/plugs/fuel etc etc all adds up to make the ponies gallop a little healthier.
Castrol Magnetec or Castrol Edge Sport are both pretty good.
2k Painter and Powdercoater
cool. is it worth puttin this in the facts section. as simple fings like this aint in there, n the haynes manual seems to me, very misleading.
anyway cheers peeps.
james
james
MikeH
VW 10/40 Synta Silver all the way. If your car has solid tappets (pre '86)and oil pressure is a bit low, then you could consider going to 15/50, but hydraulic tappet cars don't like thicker oil. The Fuchs semi-synth stuff that GSF sell is also a good brand. You can buy Synta oil from http://vwspares.co.uk at a good price. If you buy 2 or 3 cans at a time, it works out pretty cheap too.
If your car burns oil at all, stop using Magnatec, and you might find it disappears.
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
