1992 MK2 GTII turns off (engine and electrics) whilst drving
WillGT21985
Hi all,
I'll start with a little bit of back story. For about 12 months I've had a sporadic fault on my K reg MK2 GTII. From October last year onwards it began turning off and back on again whilst driving. By this I mean that the engine and the electrics turn off. This usually happens for a second or two and then everything comes back on, usually without me having to touch the key.
In July this year it turned off whilst driving and wouldn't restart, again both the engine and the electrics completely off. I had it recovered, fitted an new ignition switch (old one burnt out), and was able to drive it as normal for around 90 miles before the sporadic fault began reoccuring. That's where I'm currently at.
It turned off and on multiple times during a journey to work across a town centre with busy roundabouts so I took it straight to my usual garage. They've had it for over a week and it's not played up during their runs out in it. Their first thought was that perhaps the new ignition switch was faulty as these are now all after-market pieces and not VW genuine, but nothing happened on them so they've not looked at that. I did ask them to check earth connections, ground connections, radio wiring etc for shorts and the like but again nothing suspicious was found.
Has this happened to anyone? Any idea what I should look into next?
Thanks!
Thanks!
- GT_II
Re: 1992 MK2 GTII turns off (engine and electrics) whilst drving
The only thought I have is that if the old ignition switch was burnt out, I would expect some damage to wiring connectors and possibly the wiring. If so, it is possible there are bad connections, leading to unreliability and eventually burnout
check the x relief relay as this powers a lot of things
also check the battery clamps are tight and ESPECIALLY the fuse box wire connected to the positive pole is tight and not loose as ive had that be loose on my car and would cause it to cut out randomly
other than that your looking at earths and tracing wires from ignition and fusebox for damage and burnt wiring as unfortunately if the ignition switch is bad then more may be bad too
WillGT21985
Thanks for this. Where exactly do I locate the fuse box wire you mention? Please bear in mind that I'm not familiar with this area of the car, cheers.
if original there is a chunky red wire going from the positive battery pole to the fuse box
check that wire is tight and if you have a multimeter it would be a good idea to check voltage drops in and around the fuse box (ie 12.6v on the battery should equal 12.6 and close to it in and around the fusebox etc)
might be worth someone local giving it a once over with you to help narrow the fault down
WillGT21985
Hello again, after a month of healthy driving the fault has re-occured. This time I took it to a different mechanic and he seems to think it's a dashboard issue, with either the PCB or the processor. Maybe a damaged piece of solder etc.
Now, I've had this fault for a year, and it's cost me a reasonable amount of money, and a lot of time and anxiety whilst driving. So, I'm asking you lot for advice...do I proceed and locate an auto-electrician who can fault find behind the dash, or is it time to say goodbye and sell it as a project?
I'm imagining that dashboard fault finding is a timely and expensive process as I do not have the ability to do this myself.
- GT_II
I'm not an expert, but I would be very surprised if the fault was anything to do with electronics or pcbs. That's not to say it's going to be easy to trace the fault. Ideally you need to find an auto electrician familiar with Mk2 Scirocco/Golf electrics, rather than one specialising in modern ECU-based electrical systems
there really isnt much to these cars and as said doubtful it would be a pcb etc
i take it the car is carbureted? the only things needed to run is the ignition module on the left side of the plenum chamber and the dizzy itself
if the power is going completely off that signals something majorly obvious like power leads, earth leads, fusbox connection in the back or wiring to ignition barrel
all of these things can be checked over in a couple of hours
i would seriously get the car running and start wrenching on the wiring and associated parts until it cuts out
last thing you touched would likely be the culprit
another benefit in these motors is the parts arent really that expensive
i had a distributor hall sender kill itself which killed the car but i still had ignition lights- changed the dizzy it worked again
i had the battery fuse box live wire come loose which would kill the car and no lights on dash with no start- tightened the connection and never happened again
i lost ignition and lots of other things when my x relief relay burnt out - changed the relay for a new one and solved the problem
i had an intermittent misfire and erratic idle develop some time after the new distributor- turned out to be a failing tci ignition unit which i replaced
all of these items were less than £100 combined (some parts second hand like dizzy ) but took a little time to diagnose
i would persevere and hopefully someone local could come have a look over the car with you
I'm in south Birmingham if your willing to travel?
