Air intake - Scala
K15NWP
Air intake - Scala
Post by K15NWP »
Good evening,
Continuing the recommission of my Scirocco after a significant absence from the road, another question please?
Just a recap first, been a busy few weekends 8-)
Fuelling issue - resolved with new lift pump
Full service with Syntra oil (10w40)
New drive belt (Gates)
New timing belt and tensioner (Gates)
About to fit another new timing belt as there was some swarf at the bottom of the cover that took the writing off and was audible with the squeak; better safe than sorry!
Cold air intake. It’s looking it’s age now, and I have read a couple of earlier threads on the subject, but one question didn’t appear to be answered, or 2.
https://drive.google.com/file/d/11N42S ... share_link
https://drive.google.com/file/d/1eVRFX ... share_link
What is the diameter of the hose for another replacement solution?
What options are there, aside from main-beam delete as I rather like the 6 lamps front end :-) ?
Thank you
‘92 Scala - Alpine White
Daily 2023 Volvo S60 T8 Ultimate
Others like Yugo Cabriolet, Land Rover Series 1 & 3, Lotus 7 and more.
Membership No.1766
p in phcas
Re: Air intake - Scala
Post by p in phcas »
For what it is worth, I used heating ducting from the aux heater in my camper van. It is a little tight on the fit, but has worked OK for the last 2 years. It is like this stuff https://www.amazon.co.uk/Exhaust-Diamet ... B082KJLPVW 45mm or 60mm I believe, I would need to double check.
K15NWP
Post by K15NWP »
Thank you - 60mm looks about right from my eyeballs
Membership No.1766
