The rain tray itself doesn't have cracks, but it looks like the water can drain off of it and end up in the "puddle" rather than going out through the drain holes. The car is parked on a driveway which is pretty level.
Previously I've had issues with wet footwells, so this might have been the source. I went mad with the black silicone last year around the fresh air intake/blower motor to try and prevent it leaking into the passenger compartment. So maybe this is why I'm now noticing the puddle.
Drainage holes:
Is this common? Are there meant to be any other drain holes? It almost looks like there should be one here, next to the ignition coil.
