FIXED - Broken Window Crank Lever
smudger28
Post by smudger28 »
My son has managed to pull off the passenger window crank lever and I'm not sure how it fits back on? Is it broken or can it be fixed? Thanks.
https://flic.kr/p/2ohHJKP
https://flic.kr/p/2ohMHwF
1986 MK2 Scirocco - GTX - 120k
Re: Broken Window Crank Lever
Yes the plastic cover should pop off around where the screw is, mine did come undone them selfs over time but a blob of lock thread on the screw has worked the last few years.
On my Golf but yours should be the same.
smudger28
Post by smudger28 »
Ah ok that's how it works. I'll try and prize off the plastic arm tonight and get that fixed back on. Thank you!
