Trim/Bodykit
LauraK
Trim/Bodykit
Post by LauraK »
Hello
Looking for replacement side skirt/sill trims, any ideas as seems impossible to find?
Any help appreciated.
Also has anyone replaced the handbrake lever, looking to find a way to get it off the bar at the back end, not sure what kind of tool needed for that!
Thank you :)
Re: Trim/Bodykit
Handbrake, there should be a metal clip which slides into a grove on the bar which runs through the handbrake, remove the metal clip and the bar should push out.
You will also need to undo the 2 cables.
Re: Trim/Bodykit
Found a diagram, item 12a or possibly a circlip 12 is the bit to remove.
https://volkswagen.7zap.com/en/rdw/scir ... 11-124000/
LauraK
Re: Trim/Bodykit
Post by LauraK »
Thanks Mark1gls, really helpful, I will try that and let you know! :) :)
Blueshark
Re: Trim/Bodykit
Post by Blueshark »
LauraK wrote: Tue Feb 07, 2023 11:24 am Hello
Thank you :)
https://scirocco-delen-eimers.nl/dorpel ... set-links/
https://scirocco-delen-eimers.nl/dorpel ... et-rechts/
LauraK
Re: Trim/Bodykit
Post by LauraK »
Thank you!! Blueshark ! :)
essextom
Re: Trim/Bodykit
Post by essextom »
I also have some skirts if needed still
