Door seal trim part number and a source
Don't know German? look here
p in phcas
Post by p in phcas »
Need to replace driver and passenger door side outer trim. Cracked and falling / fallen off.
Also need door window outer seals
Blueshark
Re: Door seal trim part number and a source
Post by Blueshark »
p in phcas wrote: Sat Aug 06, 2022 8:42 am Need to replace driver and passenger door side outer trim. Cracked and falling / fallen off.
I have these in stock :
https://scirocco-delen-eimers.nl/regenl ... cirocco-2/
Joost
