speedo needle flickering
Hi again all, re my last post it should have read speedo needle was flickering god knows how I typed trousers!! So can anyone help with this--thanks.
Village Idiots
Re: speedo needle flickering
This problem has come up on motorcycle related sites.
Usually some stiffness somewhere in the drive cable. Lubricate the cable or fit a new one.
It’s cable driven so check the routing of the cable and make sure there is no sharp bends. Check the speedo cable is pushed all the way in at the back of the instruments, you may be able to get to the back of the instruments from below if you remove the cover above the pedal, I’ve not got a Mk2 so not sure if you can reach, you can in a Mk1 Scirocco and Mk1 Golf.
If you do remove the speedo cable from the gearbox end be very careful of the plastic drive cog on the end of the cable as it’s really easy for the cog to fall off into the gearbox then you are in trouble if you can’t get it out…
thanks for the advice will take a look you can get to rear of instruments if the shelf below is removed thanks again
Just go carefully behind the instruments cluster as the wires etc are all getting old and you don’t want to damage anything, might be best to disconnect the earth lead from the car battery as well?
What did you do?
Fit a new cable or just push the old cable into the back of the cluster a bit more?
I did remove the cable from back of speedo and put it back in it worked for about 10miles or so then it started trousers about so got a new cable ok now done about 250 miles with it so far
chopperoli
