Help sub frame brackets
Henryhall1
Post by Henryhall1 »
Hi my D registered Scirocco GT has had lots of work done and it passed its MOT 👍. However the tester said the rear sub frame brackets were touch and go, but he did pass it. Can anyone help/ advise where I could find a couple of good or new ones. Any help would be appreciated. Thanks
Trevor
Blueshark
Re: Help sub frame brackets
Post by Blueshark »
GT_II
Post by GT_II »
Henryhall1 wrote: Thu Jul 15, 2021 4:28 pm Hi my D registered Scirocco GT has had lots of work done and it passed its MOT 👍. However the tester said the rear sub frame brackets were touch and go, but he did pass it. Can anyone help/ advise where I could find a couple of good or new ones. Any help would be appreciated. Thanks
Trevor
Hi, I assume you are talking about the rear suspension. Do you know what the tester meant by brackets being touch and go? Was it the mounting brackets that attach the subframe to the body, the brackets that hold the anti-roll bar to the subframe, or was the problem structural corrosion in the bodywork in the area the subframe brackets are attached?
Henryhall1
Hi it was the mounting brackets that attach the subframe to the body. Thanks. Trevor
GT_II
Post by GT_II »
171501537B is the part number for the bracket/bush assembly, no longer available. Many retailers still list this part number, but just for the rubber bush, which was never supplied as a separate part by VW. VW South Africa did apparently sell the bracket separately for their Mk1 based Citi Golf with part number 161501535, but this also looks unavailable.
You can buy new ones from Germany, they should be the same for a Mk2 Scirocco
https://www.werk34.de/en/bearing-suppor ... 537-b.html
It may be cheaper to buy a complete 2nd hand ream beam as they do pop up every now and then, Mk1 Golf and Golf cabriolet should have the same running gear as the Mk2 Scirocco.
Village Idiots
Post by Village Idiots »
You sure it was the brackets on the beam and not the bodywork section these attach to?
The body sub frame is usually the suspect area.
GT_II
Post by GT_II »
Village Idiots wrote: Sat Jul 17, 2021 7:54 am You sure it was the brackets on the beam and not the bodywork section these attach to?
My thought also.
