Front spotlight adjusters
frlrubett
Post by frlrubett »
This has been covered a lot but a number of the links have expired so just want to double check.
Purchased the wrong headlight adjusters screws, they fit well for my main lights but for the smaller inner ones they dont.
Someone suggested these
https://www.heritagepartscentre.com/uk/ ... g-set.html
Is this correct, I seem to remember I need four of them for each fitting, but these are packs of three??
Blueshark
Re: Front spotlight adjusters
Post by Blueshark »
3 is enough, one is fixxed, one is used to adjust height and one is used to adjust left or right beam projection.
If you use four you can not adjust.
Joost
RussGLAuto
Post by RussGLAuto »
frlrubett wrote: Tue Feb 02, 2021 8:08 pm This has been covered a lot but a number of the links have expired so just want to double check.
You can also get them from here:
https://www.classic-vw.co.uk/scirocco-i ... 2080-p.asp
Joost is correct, only three required.
frlrubett
Post by frlrubett »
