Uprated Headlight Loom - No Sidelights - Solved
Moderator: Scirocco Register
haddock_n_chips
Post by haddock_n_chips » Sun Jul 12, 2020 3:22 pm
Hi All,
I bought one of those 2 relay uprated looms off the bay of e
Gone to fit it and I've got no sidelights!
I thought is was bringing them on at the same time as the dipped beam on both switch settings, but it actually wasn't, just dipped beam coming on both switch settings.
So read around and realised i need to unplug the dim/dip resistor with the two yellow wires under slam panel
Done this and now dipped beam comes on with setting 2 on the switch as you would expect but still no sidelights on setting 1!
Put the wiring back to standard and everything works as it should!
What am I doing wrong? Help!
W.
haddock_n_chips
Re: Uprated Headlight Loom - No Sidelights - Solved
Post by haddock_n_chips » Sun Jul 12, 2020 3:52 pm
It's OK I've figured it out!
Helps if you check whether the sidelights bulbs aren't blown before starting...! 🤣🤣
What a numpty....
Post by mark1gls » Mon Jul 13, 2020 3:42 pm
:laugh: :laugh: nice simple fix in the end. :good:
C 20 CCO
Post by C 20 CCO » Mon Jul 13, 2020 4:50 pm
Ha ha, typical scirocco personality disorder strikes again..... funny how when you do something nice for them.... they poop on the party
kind regards,
Dave.
To be old and wise......
