Evening all, could any of you brilliantly knowledgeable chaps tell me where i could find which coil i need to buy as i'm hoping it is the route of all my problems?
I have a h-reg GTII
cheers
andy
Coil
captainwow15
Re: Coil
cheers mate,
recently bought my first roc and its been playing up and misfiring quite a lot, and losing power;
http://sciroccoregisterforum.co.uk/carf ... f=9&t=2062
it had been standing for 6 years so i kind of expect some stuff to go wrong so ive replaced the plugs and leads and the RAC replaced the rotor arm after a small non-starting problem. now replacing the coil hoping that will rectify but also need to check the fuel as my breather pipe isn't connected to the filler pipe and theres gunk getting into the tank so need to sort that out too but the fuel filter seemed fine.
any help is greatly appreciated
Re: Coil
breather pipe shouldnt make any differance, there really just to relise the vapor from the fuel.
have a good check around the fuel filler next and inside of the tank for corrosion, also there could be a filter in the tank where the fuel lines exit check that if theres one fitted. All sorts of probs people get from this.
