Seem to have a squeaking noise coming from what sounds like handbreak area. It seems to be related to the speed of the wheels not the revs, as i get fast the squeak does and slower ect. Also when i turn left it goes and then when i turn right it comes back. Any clue? Could be hand break related? Or is there some else down there spinning?
Thanks for your advice.
Sent from my SM-G960F using Tapatalk
Squeaking?
- C 20 CCO
Re: Squeaking?
Mouse....... sorry, couldn’t resist.
Have you tried lifting the hand brake slightly to see if there is a difference.
kind regards,
Dave.
To be old and wise......
Dave.
Re: Squeaking?
There's nothing that rotates near the handbrake. As mentioned above it's most likely to be driveshaft/CV related and the noise is just radiating down the tunnel.
Re: Squeaking?
I see you posted up on "facecloth" a video with the noise, sounds like metal on metal scrapping to me, I guess it's something to do with the exhaust if it's near the handbrake, there's a few heat shields down there so perhaps an exhaust rubber hanger has broken and the exhaust is rubbing on a metal heat shield.
Get the car in the air and wobble the exhaust around to see/hear if it's hitting anything.
The only other things which can move down there is the gear stick linkage or handbrake cables so if no joy with the exhaust have a look at those...
Re: Squeaking?
Thanks for the advice but thats not my video [emoji23] during some research i think cv joint is sounding right, will have to wait till the end of the month to get it looked at!mark1gls wrote:I see you posted up on "facecloth" a video with the noise, sounds like metal on metal scrapping to me, I guess it's something to do with the exhaust if it's near the handbrake, there's a few heat shields down there so perhaps an exhaust rubber hanger has broken and the exhaust is rubbing on a metal heat shield.
Re: Squeaking?
Thank you! Ill have to get it looked at!mr.brown wrote:There's nothing that rotates near the handbrake. As mentioned above it's most likely to be driveshaft/CV related and the noise is just radiating down the tunnel.
Re: Squeaking?
Oh must be someone else posting on face book about a squeak. ![Very Happy :-D](./images/smilies/icon_e_biggrin.gif)
