Hello Ladies and Gents and Happy New year in advance.
I have just noticed that the carpet near the door (drivers) is damp.
Would this be the main door seal to blame or plastic one? It clearly looks like its gathering in one area as the sound matting is sodden there specifically. Thankfully not heater matrix been near the door so what you think?
Mick
Mk2 Moisture around carpet near door
Re: Mk2 Moisture around carpet near door
It could be from the door or damaged/missing membrane, however when my windscreen was leaking, the water went straight to the rear floor area. So worth checking behind the dash for evidence of water leaks too.
'89 Sapphire Scala Inj.
Member No. 1455
Member No. 1455
Wouldn't it be ironic if it was the membrane after my last postblakey wrote: Tue Jan 01, 2019 3:58 pm It could be from the door or damaged/missing membrane, however when my windscreen was leaking, the water went straight to the rear floor area. So worth checking behind the dash for evidence of water leaks too.
It was a very concentrated small patch right where the door corner area meets the floor carpet drivers side front .Thats why i assuned it was from directly above.
My car has this horrible spray adhesive down the gaps so its hard to pull away and inspect , is that standard?
This car also has a webasto sunroof
