Leaky Sunroof
Re: Leaky Sunroof
Your Sunroof is an aftermarket type, VW at the factory only fitted metal type sunroofs.
Have you tried cleaning the seal then smearing on some Vaseline or silicone grease to the seal to soften it up a little and help seal it to the glass?
Is there a make or any marking on the handle etc to see if you can buy a new seal?
Re: Leaky Sunroof
Pop it out,red button detaches it, give it a really good clean, especially the rubber.
An old toothbrush helps. Dry it off you can use a gentle heat on a hairdryer
Some people suggest using vaseline well worked in as this will cause the rubber to swell, but others are horrified at the thought of putting vaseline near rubber?
The choice is yours.
If this fails there's a company that does replacement seals for around £70. I seem to remember they're in Bristol. If your car is damp anyway this can condense on the glass and drip down.
oops beat to it
oops beat to it
Danny
Re: Leaky Sunroof
Cap’n Tolley’s Creeping Crack Cure might be your friend in the interim, but a new seal or rubber washers where the bolts go through the glass are likely to be what you need to fix the leak(s) altogether.
- scrumpyone
Re: Leaky Sunroof
https://www.bristolsunroofs.co.uk/DannyH wrote: Thu Dec 06, 2018 1:13 pm
Dave
Register No:1110
'79 MK1 GLS (R.I.P.)
'91 MK2 GT2 (alive & kicking)
Register No:1110
